G
Guest
Guest
what purpose do buffers serve in audio circuits usually? are they mostly used to isolate things like led display or other circuitry?
i have the ic opamp cookbook and was going to build the variable dead-band circuit. im building it for school and this book is so dense that i wont be able to get through the stuff i need to so that i can figure this out myself.
i wanted to build this circuit to run audio through it and use it as a distortion generator.
do i need to buffer the input and/or output? what will be necessary to make this circuit ready to operate in a line level configuration?
