lordnielson
Member
atticmike said:the fuse that comes with the mnats cart, does it withstand the eu voltage of 230?
Yes. I think it's 250ma.
peterc said:@atticmike
1000pF = 1nF = .001uF
FKp2-1000/100/5 means 1000pF / 100v / .2"(5mm) pin spacing
Peter
tko said:3. If there is no resistor listed to add to the attack or release pot in the BOM does that mean is not one? In the wiring instructions is has a section to add a the specific resistor. But in the BOM it varies.
acoustix said:Now, I solder the board.
All res, and film caps are on the boards.
What kind of pict you want ? Full empty or populate ?
atticmike said:has anyone put a revision A recently together and can provide me with a high res bird's eye picture of the board?
mnats said:atticmike said:has anyone put a revision A recently together and can provide me with a high res bird's eye picture of the board?
Any reason why it has to be recent? Is the one on my site not clear enough?
atticmike said:mnats said:atticmike said:has anyone put a revision A recently together and can provide me with a high res bird's eye picture of the board?
would love to compare the components locations for whether I have placed them all correctly or not, like a final comparison.
otherwise I will have to get a color table and check the rings on the resistors and such for their correctness.
Mike
