TijuanaKez
- Joined
- Jul 19, 2011
- Messages
- 51
It's actually correct.
As the ratio gets higher on 1176 (moving from 4:1 to 20:1), the threshhold gets higher. So you "see" less GR.
To see the ratio, you compare the input to output over a couple different points. Keeping in mind your ratio decreases toward the "knee" and FET saturation.
Mike
Edit: Link about measuring ratios:
http://www.axtsystems.com/index.php?option=com_content&view=article&id=54:1176lnratios&catid=34:1176ln&Itemid=62
Ahh I do remember the threshold being ration dependant now. I followed that link though and it still doesn't seem right (see attachment) One thing I noticed that could have something to do with it.... when I set the input to 'straight up' (-24) I only have to set the input to -48 to get 0 on the meter. When I tested it next to a friend's real 1176 he said mine was 'super hot' in comparison to his. Is this normal for the mnats rev d board?
I'm not exactly sure how to determine my ratios from the readings I took but it doesn't look right compared to the graph in the link. It seems I have to turn the input down a lot to get below the threshold
Other notes: I used logic test oscillator and metering to do this test to get precise values. With my Duet 2, I set up logic's test oscillator to 1Kz -12db and logic's channel fader to +1.6db to get exactly 0.775VAC at the input XLR on the 1176.
I setup an input channel (set to XLR -10 in Maestro) and a gain plugin set to +3.3db to get exactly 0db on the logic input meter when the 1176 meter read's 0db with GR off the meter set to +4. I dropped the test oscillator level by -3 each time and took a reading off the logic input channel meter. The Input channel meter on logic was pretty spot on with the 1176 +4 meter reading.
