sorry, yes, you're right, it was very late, and was a long day LOL. Leave the resistor out until it is time to calibrate...
sr1200 said:sorry, yes, you're right, it was very late, and was a long day LOL. Leave the resistor out until it is time to calibrate...
sr1200 said:Id like to know if its possible to use 3711's instead. HFE min on those is like 180... as opposed to 100 on the 3707s or (most likely) im reading something wrong.
dbonin said:Out of frustration I turned to alcohol.
Alcohol and a tooth brush.
I brushed the back of her with vigor, determined to remove all the plac and tarter. I grabbed some dental floss and cleaned those hard to reach places. My dentist would have been proud.
I let her dry, plugged her in and let her sit, warming up for about 30 minutes - I wanted to take it slow tonight so I left her alone. Tonight was going to be special. When I returned to the room she was basking in a warm glow, laying open and waiting on top of my bench. My investment in alcohol was indeed a good one. The sound of a Fender bass, slapping and sliding funky notes drifted in from outside.
I tweaked and twisted and probed my way past first base - q-bias - such a tease. "Yes!" I hissed.
I injected her with hertz and I tweaked and I twisted and I probed - things were really starting to heat up, I could feel it. I stood over second base, looking down at her, triumphant that I had made it this far with her. zero on r74 and zero on the vu - second base NEVER felt this satisfying before.
Third base was literally waiting beneath my probes. I injected her again with the same intensity as before. Her meter responded. On. Off. Tweaking her input, her output - watching her respond and then.... "Fluxxxxxx!" I yelled.
But only she hadn't made it. Maybe she was faking it all along?
The final calibration step (third base, baby), just using the front panel knobs, doesn't seem to work as Mnats video. I can get the meter to go from 0 to -10 if i set it up and then use the push buttons: GR "on" - zero vu
hit +8 on the meter button - the vu drops to -10 vu
When I use the knob to switch GR on/off I see no movement of the meter the way mnats shows it.
I can't believe I made it this far with her only to walk away blue, if you know what I mean. I'm going to buy more alcohol and try to get to third base again tonight. It's Friday and tonight I'm gonna score, I can just feel it!
sr1200 said:The alcohol isn't going to fix anything unless there is a lot of conductive residue on the board (which there shouldnt be).
First, make sure you put the jumper BACK into the cirucuit.
Second, VU mode in the video = +4 on the pushbutton version.
Third, make sure when you engage the compressor you turn the attack ALL the way up, dont just click the knob on, go all the way(the fastest attack setting).
Fourth. Instead of guessing (putting the knobs at 50% 50%) crank the input volume ALL the way up (max) and bring the OUTPUT up to get to 0 on the meter.
If when you disengage the compressor you get no drop check the following:
1) make sure the wires on the back of the attack pot (switch part no the pot part) are wired to the board properly
2) make sure you have continuity from the molex connector on the Ratio board to the main PCB
3) check that Pin 4 on the ratio board has continuity to the TOP CENTER POLE of the switches (by top im referring to the top center pole while it is installed in the traditional vertical position... if you have no continuity there you may have to jumper it (see germoju's posts on previous pages)
ILOVE1176 said:Hi guys, I am ready to calibrate but I need some advice and help. The calibration videos aren't of the push button version so I'm slightly confused as to what buttons should be engaged and which knobs turne ect. Do I still need to bypass my build via shorting it as in the video? Also, what's the best way to run a 1khz tone into the unit from my daw?
Thanks in advance
