jplebre said:
did you follow the recommendation of powering up the board with the PSU part only?
if so, was it working then?
Honestly. I'm a jerk and I didn't. I Decided to learn my lesson this time and now I am going to pay for it by desolder all the components leading out of the PSU and test again.
[/quote]
once the power is connected to my board everything goes out of wack.
Did you check o/p transformer wiring? there were quite a bit of problems with that reported.
you can also disconnect everything out of the VR section as that will take quite a lot of stuff that is connected to the -10 rail.[/quote]
Maybe i'll try that first.
[/quote]
What do the DC points measure out of curiosity>
[/quote]
DC reads 0 on both rails
checking resistance between AC and the test points shows continuity
1.229 K at the +30 tp to the AC point near the out tran
222r on +30tp from the other ac point
1.226k from +30tp to CT
1.58k at -10tp from both AC's, CT and ground
I dont know if that info helps
My output tran is wired correctly and I have reflowed the solders.
My wiring parts and components are identical to the black face we built. Everything was ordered together and built together step by step on the same assembly table. That is what is confusing me here. A bad component seems more likely than a wiring error.
My version of the PCB also has the ground wired to the - on C25 as instructed.
