Echo North
Mr.Franky said:Hey guys,
I just finished building a Rev D a few days ago. It worked perfectly ofr about 2 days, but now when I fired it up, the VU meter light bulb doesn't seem to work. The sound still sounds the same though. Nothing else weird going on so I suspect it's just the light bulb? How can this get broken by just sitting there? Would there be something wrong with my wiring? I would suspect not.. How can I fix this? Add 2 colored leds at the back of the VU meter?
Thanks in advance! I'll be buying some more kits in the near future for sure!![]()
Mr.Franky
What is the V across the lamp pins? Should be about 11VAC. If that's what it is probably just bad lamp.
You can string two LEDs in series across the lamp holder but you'll need to drop the voltage.
I can send you a new lamp.
Mike
