mattvon said:I do, I see a significant drop in the meter when following the conditions above. The needle drops to about "-4.5" when I switch it on. I also hear a significant drop in sound level.
omribgr said:ohh sorry I wrote -0.97 but i meant -9.7V, my mistake...the problem is with the +37V
I've checked the AC voltage that the PCB gets from the power transformer and it shows 28V (AC) for each AC input (there are 2 on the PCB)
can it be the problem ? i think the power transformer suppose to supply 25V
omribgr said:first of all - thanks a lot !
so I've checked every resistor prior to placing them with two different multimeters ,i bought everything from hairball and did every step in their building guide..
i've added here the power supply section from MNATS website.
i think as you say maybe a bigger dropping resistor will fix it ... but i'm not sure which resistor to change and what size :\ so if you can tell me from this schematic what can i do , I'll really appreciate it![]()
omribgr said:O.K i think I'm getting closerso i bought 2 new VR1 and this is what I've found:
1)the legs of the first one shows 34.8V DC and the second one shows 36 V (which is better than 37 )
2)it shows the same voltage on the legs of the regulator and at the checking point, which means that
now the situation is better (34.8V)
so how bad is it ? can i live with 34.8?
thank you all![]()
omribgr said:so that's where it stands now : (I took some pictures to make it easier )
1) the 28.1V is the AC power of input 2 ( one gets the same power)
2)the 34.7V is the DC power on the leg of the R87 (1.1k resistor) , this is the problematic value (suppose to be 30V)
3)the -9.8V is the DC power on the leg of the CR6 Diode (which is a correct value )
4)the 12.12V is the DC power on the legs of the 220 ohm resistor (R89)
5) the 37V is the DC power on the leg of the CR7 Diode .
6) only that you'll see that everything else is ready except the PCB
so my guess is that the problem is on the AC power that the PCB gets, I think it suppose to be 25V AC for each input .
i also think that the Diode (CR7 ) should be 35V DC (you can't see it on the MNATS schematics but on the original schematics
on the dot between the C25 and CR7 )
what do you think guys? if you agree maybe i can drop it somehow with a resistor ! (before the PCB)
and dmnieto , thank you for the help , really, I'm hopeless!
the links for the pictures: (direct links to Dropbox)
https://dl.dropboxusercontent.com/u/83599022/1176/picture01.JPG
https://dl.dropboxusercontent.com/u/83599022/1176/picture02.JPG
https://dl.dropboxusercontent.com/u/83599022/1176/picture03.JPG
https://dl.dropboxusercontent.com/u/83599022/1176/picture04.JPG
https://dl.dropboxusercontent.com/u/83599022/1176/picture05.JPG
https://dl.dropboxusercontent.com/u/83599022/1176/picture06.JPG
omribgr said:actually its really hard to see the colors on the pictures..
but the colors are RED-RED - BROWN -GOLD - for the 220 Ohm
and the 1.1K is BROWN- BROWN - RED- GOLD ..
and of course the resistors checked before it was soldiered with a multimeter
you can see here:
https://dl.dropboxusercontent.com/u/83599022/1176/picture07.JPG
https://dl.dropboxusercontent.com/u/83599022/1176/picture08.JPG
omribgr said:do you think i should buy a new PCB or going to a professional lab will help me ?
