quinncmusic
New member
- Joined
- Nov 29, 2013
- Messages
- 4
Update,
Today me and Dbonin spent a few solid hours checking through the whole unit via Skype and I think he has found the root of the problem, but we are unsure of how to fix this.
-We checked all voltages and all looks good except R52/53 which seem to be around 4 volts higher than usual.
-We have ruled out a wrongly placed capacitor or resistor
- I ran the 1k signal through the unit and back into pro tools - shows both the upper harmonics, but still no compression!
Lastly we did the test on the ratio board testing the AC and DC with pad 22 and what we found is that not only is the level low but the ratio selection does not affect the voltage at all like it should! We are getting close...
Does anyone know where to go with this? Again, the unit passes signal fine but no compression happening!
