here's the deal. the two decks are both what is sometimes called a "dB" taper, which is a very unusual type of modified log. instead of each pot reaching 50% of the total resistance at 50% rotation like a linear, or 10% resistance at 50% rotation like a log pot, it is much less, like 2% resistance at 50% rotation. if you take a bunch of points and plot them, what you'll see is that the value stays quite low (almost like a linear) until very near the end and then shoots up. this is also why the end values you measure will be quite different from unit to unit. the exact value at each end doesn't matter that much, only that it should be "alot more" than the value in the middle.
i've looked around, and i doubt you'll be able to find anyone willing to make such an oddball taper pot these days (except for PEC, who are already doing it), and certainly not in the quantities that you're looking for. but good luck anyway; it would be great if you did find something.
ed
