[quote author="pH"]Quick question about using the input transformer board with the Altran: if I'm reading the board correctly I need to link B to C, and E to F, yes?[/quote]
Yes, that's what I put at the bottom of the board.
[quote author="pH"]This would link pins 2 and 3 to the ground plane of the little board. [/quote]
How do you figure? Note that where it says "Altran C-3837-1" there is an arrow indicating where pin 1 goes. That means pins 6 and 7 will be connected to the ground plane.
On the Altran, pin 6 goes to the can. On the Cinemag CMLI-15/15PCA (a 1:1 transformer not explicitly shown, but that shares the same footprint and pin 1 assignment) pin 6 goes to a shield and pin 7 goes to the can. It wasn't easy trying to fit all the information at the bottom of the board, so even though it says to connect the two links, only one is going to the can with the Altran.
[quote author="pH"]Can't find a pinout for the C-3837-1 so I'm wondering what's happening here.[/quote]
I've now linked to it from my Rev D page. Here it is courtesy of Ed.
