canidoit said:- Which is + and - on the Mnats altran input transformer pcb board that connects to the "in" of the Main Mnats PC board?
See Skylar's rev. 3 drawing.
- How do you wire the Hairball Fet Compressor Pot attenuator? Skylar has a different pot for his diagram? Is there a wiring diagram or instructions for wiring the Hairball Fet Compressor pot somewhere?
See Matta's attenuator drawing.
Hairball Meter Push Button PCB board
- Also, if you use the SPDT switch on the attack pot, how does it change the wiring for the Hairball Meter board and Skylars diagram?
Read the section regarding SPDT switch wiring in the Hairball pushbutton guide. Then disregard the switch wiring (pad 22, GRN and BLK) shown on Skylar's drawing as you are switching using a different switch.
