Grooveteer
EDIT: Problem solved.[size=6pt] Ego slightly bruised. :
I have wired R71 off-board and wired it incorrectly.
Corrected the wiring and it made life good again. ;D
Hi guys,
My build seems to have a problem; The Q bias calibration went fine, but when doing the discrete meter calibration I can't get the meter to zero and have 0,00 V on R74 at the same time. When I adjust R71 the meter goes to the right but no further than say -3 dB. After that it just drops down again. (quickly). Have already replaced Q12 and Q13 and I have changed R71 to a 5K trimmer. No luck.
The only way I can get the meter to zero is when I have about 0,7 VDC across R74. Not good.
I'm using 2N5088 and on my DMM Q12 and Q13 read 507 and 509 HFE, so that should be OK, right?
Any clues? Hints? Tips? Tricks?
Cheers!
G
Hi guys,
Cheers!
G
