Ringwraith said:
In the GR Meter Driver section between R44 & R69. It says "norm short"
Sean
Sean, thats called (x amount of pin) Pin Header Terminal Strip. You are right, I think it is not in the list. Sorry
. They use that so you can short connections or not. You use this little connection thing that is used for hard drives to make the settings master or slave on the hard drive. Get that part from a computer store or general electronics store or if you have an old hard drive that has a spare one it's not using.
Here is a link to what you are talking about, its a 28 pin version which you cut to how many pins you want. On the Rev D it uses 3 pins, so you chop that amount. This allows you to short or not that section for calibrating on the R44 trimmer pot. I think what it does, is either makes the R44 trimmer pot in circuit or not. When calibrating, the R44 is not meant to be in circuit, but once you have calibrated the unit, you put the R44 back in circuit by using the little hard drive connector thing. Something like that. This makes it easier to calibrate than having to desolder and re-solder R44 for calibrating. You can get this part in Australia in general electronic stores, so it should be the same for the country you are from as well.
http://www.jaycar.com.au/productView.asp?ID=HM3211&keywords=terminal&form=KEYWORD
Here is a pic of what you are talking about on my build from what I understand. See the little white plastic thing, which is what I got from my computer to make the setting of the R44 in circuit or not. I have it not shorted on the pic, and it is actually hanging off the last pin.
If you are from Australia, I will send you some for your build, just pay for postage.
