commanderberti
What are your experiences with what the last dB of noise improvement brings? PSU filters, special capacitors, transformers, which tubes... I'm grateful for all your tips!! Thanks
thanks, what tubes ecc83 can you recommendA good tube! (The quality of tubes nowadays isn't what it used to be...)
which tube(circurit) do you prefer?..basically, the ECC83 is not suitable as capacitor microphone front end, grid leak and miller capacitance are prohibitive..
The reason the chinese started using it for mics was most probably just that they could get very-cheap "only-one-half-working" ecc83's, rejects from current production (check the original tube in there - most of the time the "other half" of the mounted dual triode is defective).
/Jakob E.
How quiet do you really need a tube to be? I personally use tube mics for their coloration which starts to show at high-ish SPL. If you use a tube mic at low SPL where noise is starting to play a role you don't really get much of the tube goodness. My approach is FET for low noise, Tube for louder stuff where these mics really shine. Unless you record something with crazy dynamic range. I feel when people talk about tube mics noise as an issue it's where it becomes really obvious, where you clearly hear the noise in the recording. Couple of db in noise floor difference shouldn't be a deal breaker.What are your experiences with what the last dB of noise improvement brings? PSU filters, special capacitors, transformers, which tubes... I'm grateful for all your tips!! Thanks
A good example of a nice bit of extra noise is the key click and generator 'leakage' on a Hammond organ....I am also a synth guy, and we use noise as an enhancement. What is a Juno 6 without it's noisy chorus? There's something nice about little bit of noise, but that's just me.
