Voodoobeat
Active member
- Joined
- Jun 19, 2013
- Messages
- 30
anybody acutally build a unit from ChrioN PCB copies?
Voodoobeat said:anybody acutally build a unit from ChrioN PCB copies?
Potato Cakes said:Make sure your secondaries that you tie into the PSU are connecting to the rectifier AC connections as shown on the PCB overlay in the manual. Make sure that measuring voltages on the secondaries while they are connected to the PCB are about 30VAC. If that is the case, then you get to do what we all get to do when a freshly built board doesn't work correctly..... check all the solder points and component placement and orientation. The PCB is indeed correctly laid out and does work when built as per the BOM and instructions.
Let us know what you find.
Paul
dogvoid said:Any proposal to "improve" the sound quality with components in specific parts will be welcome![]()
Rob Flinn said:Did the first unit you built sound sub standard ?
warpie said:transformers?
TwentyTrees said:Agreed - “improve” is a hugely subjective word, to different folks it could mean make it as clean as possible, as authentic as possible, make it truly funky, or almost anything else.![]()
I’ve not built mine yet, so this is an open question and I’m genuinely interested in your thinking - what are you looking for that’s different from your first build?
dogvoid said:Yes, Transformers use the carnhills the same as Chandler:
CA-18-VTB9046 input
CA-18-VTB2281 output
The upper next option would be sowter ... that I know.
warpie said:What I meant is that the transformers might be the first thing you should be looking at if you want to experiment.
dogvoid said:But I understand what you say, thank you very much for the observation.
ron_swanson said:On page 2 of the manual there's diagrams showing both a DPDT switch and a relay? Is this indicating that either a switch or relay can used (either / or) or both must be used to perform the bypassing function? My read is the instructions/diagrams indicate an 'or' configuration.
In previous builds I have built where a bypass circuit was in play, the bypass circuit completely bypassed the entire circuit. Meaning the audio was bypassed before and after the the I/O transformers - two relays per channel. From studying fripholm's schematic, in this build it appears that while fulfilling a bypass function, the actual bypassing is being made from within the circuit using either a physical DPDT switch or a 24VDC DPDT relay.
fripholm said:Either way.
A DPDT switch can perform the bypass function alone and a relay can do that as well. As soon as you want to indicate with an LED you'll need both, as in your case (or in my, for that matter). You'll be using the switch to toggle the LED and the relay - which in turn does the BYPASS. This is what I did with the british style square switches.
The guide does not cover this case - only the bypass function by itself, done by either a switch OR a relay.
In this case, BYPASS only bypasses the compressor stage. The signal still goes through the input transformer, the output stage and the output transformer. I still wanted some coloration instead of a full bypass - but there's other ways, although not covered in the guide.
Hope, that clears things up.
