kazper
From what I can remember when I was looking at the PCB's I have, there schematics and the ones I have found.
PCB Layout is very close to the same.
PCB numbers don't match exactly.
Schematic and Original schematic is laid out the same, just slight variations on some values. One board has lots of variances, more than the other ones.
I've stuffed most of the boards resistors. I think I came to the conclusion to have the home Etch and schematic handy. Stuff the original schematics values that there is no conflicting issues, verifying the connections to other components as a check. I think I have 90% of the resistors stuffed going through it that way including some transistors and diodes.
For the diode bridge, look at the 33609 thread (match them with a DMM) I had a good quantity of diodes so I found enough to all test the same and stuffed the HBX 31 area on the BA185. I also had lots of tested diodes so close from matchmaking so I stuffed those on the BA192
