Echo North
Make sure your voltage selector switch is set right.
115 - Americas
230 - EU
115 - Americas
230 - EU
ganymedestudios said:I did have it set incorrectly. Weird, I could've swore I followed those instructions early on in the process thoroughly. The cathode is now reaching 29.75 V, however the Diode is sitting around 0V though. Thank you for all the help, I appreciate it.
ganymedestudios said:I made sure the 1K resistors are correctly soldered and the diodes and now the voltage for the -10V diode is spiking from +6V to +0.5V.
ganymedestudios said:Yeah, sorry I thought I mentioned that in the first post. That's why I brought up the broken trace that I had fixed, thinking that might be the cause of it. Sorry for the confusion but now the -10V diode seems to be sitting right on 0 or -0.1 or so.
ganymedestudios said:Actually I did not check the power supply before populating the rest of the board so I suppose thats something I messed up. I'll keep messing with it a little bit and if I can't figure it out, I'll probably just end up sending it in and learning my lesson for the next time I do this build.
bazmcc said:Hi all,
Just completed the build but having a couple of issues when beginning to cal the unit. I have an experienced tech friend who has looked at it but I have a couple of questions;
- When measuring VAC/dBU across the input XLR, my friend's Audio Precision sig gen / meter measures a drop of approx 7dBU as soon as I plug into the 1176, even when not powered up. Seems to be something like a dead short but beep testing across points suggests everything is good and there are no shorts. Any advice?
- Should the input transformer measure 50 ohms between XLR input points 2 & 3?
Thanks all!
mrbobbailey said:I'm on the build of my 2nd RevA FET Rack and just finished building the power supply. The first unit went well, though I've not calibrated it yet. On this build I'm getting:
- IEC Inlet = 0.2 ohms as expected
- cathode of CR8 = +30V DC as expected
- CR9 = -41.65V DC where I should have -10V
I double checked the C9 solder and it seemed fine. I then tested the two 1K resistors (R81, R82). I'm not getting a reading from R82. Do I need to de-solder or anything to get a proper read? R81 came back fine. I think R82 is faulty. Would that cause the faulty diode reading at C9?
Hairball Audio said:Best option would be to lift one leg on R82 off the PCB then test the Ω across the 2 legs. You should get the 1K reading.
mrbobbailey said:Thank you. I did that and got 1K as expected. I did get a bit of a pop when removing my DMM probe. That leads me to a new question. How do I discharge the board when taking it out to continue work on it? I hope that hasn't damaged anything.
And back to the original question: What else should I test regarding the -41.65V DC reading on CR9?
Hairball Audio said:You can connect the across the terminals of the power supply caps with some insulated wire in series with a higher W resistor. Like 10K/5W. You can think about the charge across the power caps and relation to ohms law to make sure you have a reasonable W resistor that will work.
There are some other methods (insulated screwdriver) but I'll let you google that and decide for yourself if you think that's safe.
Seems like you're measuring closer to what the unregulated/dropped voltage would be directly off the secondary on the neg rail. You're using the chassis as your ground reference? You have all 3 L-Brackets securing the PCB to the enclosure (some of these have an grounding function)?
What is your DC voltage on all 4 of the 1K resistor pads?
Mike
mrbobbailey said:Thanks for the quick reply, Mike! Brilliant! I don't know why, but I only secured 2 of the l-brackets. I'll be that is it. Thank you.
Hairball Audio said:Seems like you're measuring closer to what the unregulated/dropped voltage would be directly off the secondary on the neg rail. You're using the chassis as your ground reference? You have all 3 L-Brackets securing the PCB to the enclosure (some of these have an grounding function)?
Mike
mrbobbailey said:Unfortunately that was not it. Still measuring -45V range
4 Pads
R81 = -45.17 & -45.13
R82 = -45.36 & -45.19
