Hairball Audio said:Q13 is crazy off. You may want to replace it.
OK, ordered and installed new 2N3708 for Q13. Readings about the same.
jdier said:OK, ordered and installed new 2N3708 for Q13. Readings about the same.
What should these be reading for a Rev A unit?Hairball Audio said:I doubt it would help to hear it.
With a 1K/0dB tone at the input, set your unit to:
in and out at 12 o'clock
attack in GR OFF
release FCW
20:1
Meter: GR
What is your AC V at TP1, TP15, TP17 and out + with respect to ground (chassis).
Mike
cyberlogic said:What should these be reading for a Rev A unit?
On both recent builds (A and B), I get (All VAC, ref to chassis GND):-
TP1: A-.140V, B-.145V
TP15: A- 3.72V, B- 3.72V
TP17: A- .67V, B- .71V
Output + to -: A- 10.23V, B- 10.90V
But the output is clipped, I have to reduce the input to around 34 to get rid of clipping and drop out to around 7.30V (+20dBu). Seems like the input gain is too high?
cyberlogic said:OK, good to know the numbers are close.
With a 250mV input signal at 1KHz and the output at +4dBu, THD is around .23%. Pretty much the same at 10kHz. Increasing output doesn't add more distortion. The input seems to be the stage that is sensitive to over-driving.
With the taper on the new pot and the fact that this is typically used on line level signals, would reducing input gain a bit not be an option worth considering? I also see a lot of signal bounce when making level adjustments at the lower levels...
cyberlogic said:Also, it seems to me this would affect your recommended Q Bis procedure. With .775VA in, Input at 24, etc, there is significant clipping in the input stage, typically on the positive side of the waveform here. Shouldn't this be done using a linear signal?
cyberlogic said:Thanks Mike, I appreciate all the information and you taking the time to consider all this and write back to me.
I really just want to make sure it is working as it would be back in the day, warts and all.
ds
cyberlogic said:Another question:
How much should the release and ratio controls affect the signal when the gain reduction is OFF (attack pot switch)?
Thx
ganymedestudios said:I finished the assembly of the kit and first tested the ground as instructed and it came back at 0.2 Ω so I moved onto switching the Meter to GR to test the Cathode and -10V diode, neither of them came out to the proper voltage. The cathode that was supposed to be +30V is only +16V and the -10V diode is -6V. Any ideas what the problem could be?
Side note, earlier in the build, I broke a trace and fixed it by soldering some copper wire to the terminals that the trace connected. (Not sure if this could be causing the problem).
Hairball Audio said:Make sure the broken trace didn't have more connections coming off it. They are not always point A to point B. Sometimes they are Point A to point B, C, and D. Check both side of the board and check the schematic to confirm.
With the unit ON, what is your AC V between ground and each orange secondary wire?
Mike
ganymedestudios said:The voltage between the ground and orange secondary wire seems to be -0.001V. The trace that I replaced was from R26 to C12. It doesn't appear to have any other connections but I'll keep looking.
ganymedestudios said:Sorry I must've been measuring the wrong wires, if you're talking about the orange wires running from the transformer, the measurements are 6.3V and 11V And no, I've been measuring in AC.
