Hairball Audio said:
Does the trimmer on the front (R71) do anything when turned?
You were able to set the NULL?
You're getting a 10dB drop at the output?
Hey mike,
Thanks for getting back to me!
Yes yes and yes. All VR pots work. Null adjust moves the needle as expected.
Just went threw and calibrated it from scratch.
The VU shows no gain reduction when the input is increased with the attack and release full CW with 20:1 ratio and GR button depressed.
Could it be a short in a switch?
- If you're getting 10 db of GR, then the sidechain should be ok.
- If you we're able to NULL the meter, your transistors should be matched.
Start with the tracking adjust centered and set your unit to have 10dB of gain reduction on the output. With the unit in GR OFF (10dB on the output) trim the R71 zero adjust to 0 on the meter. Then switch to GR ON (0dB on the output) and adjust the tracking for -10.
Where does this go wrong for you?
Mike
