Echo North
jgremlin said:Been away for a week. So I checked the DC volts against the schematic and it seems like all are pretty close to where they're supposed to be. I didn't find any that were wildly different from the spec.
However I think I may have found a clue. I was going around the board with a finger applying pressure and bit of wiggle to the caps and FETs seeing if I could find any loose/suspect connections that might have an impact on the meter. That's when I touched Q6 and said holy toledo that's hot. And that's when I remembered that Q6 is supposed to have a heat sync. I completely forgot to install it before power up.
Any chance I might have cooked the Q6 and that could be my problem?
Usually if Q6 has failed, R32 will be burned.
I would suspect something in your GR meter section which should be marked on the box. Make sure you don't have your 100Ω and 2KΩ trimmer swapped.
