Echo North
Diamondj421 said:New idea. Can someone PLEASE post a picture of a fully functional Rev D PCB that I may compare to. I had some left over resistors that I had to install from the interactive map. I'd just like to see if I possibly have an extra resistor somewhere or not. Can't find a pic of the new Rev D anywhere though. Thanks.
Visual comparison is mostly useless. It's a circuit issue. Soldering seems good, but I can't really tell, again pictures rarely help.
1) The QBias is set right?
2) Now you're stuck at null adjust right?
3) You have the jumper in the correct location?
4) You've verified the component values agains the Rev D map? Remember in the guide there is a link for helping read color codes.
5) Look at the GR Meter Driver section here (older schematic but mostly accurate):
http://mnats.net/files/1176REVA_125_VOLTAGES.pdf
How do those DC voltages measure.
6)make sure you didn't mix up the 100Ω and 2K square trimmers.
Mike
PS: Also remember we have flat rate repair if that interests you.
