Echo North
Potato Cakes said:Mike,
Just wanted to report that Active Stereo link works very well in my tests with program material. Using just tone is not a great indicator of whether or not it is functioning properly. Both compressors seemed to track the same and it definitely sounded like both sides were being compressed equally.
My one question is, since the new PCBs don't have holes drilled on all four corners, how you would recommend mounting directly to a different chassis for stereo builds? I guess one could rig up some sort of support for the side that does not have mounting holes. That was the one of the first things I thought of when building the units.
Again, the new rack compressor kits are killer! I'll post some notes a little later that may be helpful for people building these units. Or it may not be helpful.
Paul
That's funny, I had the same issue in testing. I can't believe I forgot to mention it earlier. Ya the sine wave just tracks poorly, I suspect it may be a phase issue in the summing amp but who knows. I pulled my hair out over it for a few days until I used actually program material and got much better results. I like it too.
For stereo builds we're still recommending the older boards for now. However, as you've mentioned, with a little ingenuity you could get these working in a dual build.
Mike
