Mike!
The new kits are awesome! I was able to build two Rev A's in about the same time it used to take me to build one! And the new chassis is very sexy, very professional looking. I got both of them built up and calibrated without any issue.
The only I have to figure out is the active stereo link. Disconnected both units seen to performing as they should. With the active link engaged, they are about 4-5 dB off on the metering, and this tracks when either compressor's input controls are adjusted (yes, I have checked to make sure one is send and the either is receive). I also confirmed this discrepancy by metering the XLR outputs. I had calibrated both units twice just make sure I didn't make a mistake there, so I guess I just have to see if there is swapped component on the active link card, unless there is something else I don't know about or if there is a super secret procedure I am not aware for setting both compressors for stereo linking.
Again, awesome work. I look forward to doing more of these.
Paul
Paul
