Harpo
doesn't look to be working correctly...Deejsirois said:Q12: C= 26.23 ; B= -9.14 ; E= -1.59
YoDudeRock said:Mike,
Thanks so much. Just wanted to follow up. I finally, reluctantly replaced the rest of the 2n3707's at Q9, Q8 and Q7. And success! Voltages are all rock solid now and the same with the VU. Before, voltages in the GR Control Amp section were meandering all over the place like a stock ticker during the trading day.It was obviously one of those 2n3707's causing voltages to fluctuate in that manner. Hopefully this helps someone else in the future.
Thanks again,
Chris Trentham
YoDudeRock said:Mike (and friends)
I am working on two Rev A's and I ordered the matched 2n5457's and two stereo link cards.
Question...Is it important that the hFE of Q12 and Q13 in both units (all 4 transistors) be matched as closely as possible?
Is there any advantage to matching all four transistors to the same value?
The reason I ask is, right now I don't have 4 that match, I have 3 at 405 hFE and 3 others at 410 hFE (and various others).
Also, any other tips to "matching" units? The guy I'm making these for says he wants them "matched as closely as possible".
Chris
I'm testing my 2 Rev A's with Active Link cards. I noticed there is a little bleed from one unit to the other, when Linked. If I only send a signal only to unit 1, I'll still see about -50db coming from Unit 2 on the other side (in my DAW, Reaper) and vice versa. Is this normal? I assume it is since this is living, breathing analog. I tried recording it and it's basically inaudible.
This is for a customer of mine, so I didn't want to send it to them if this isn't normal.
Chris Trentham
More_Gain said:Hello everybody,
I've just completed the assembly of a Rev A kit I bought about a year ago (it's a 2017 v1.14 pcb) . I have +29.7vdc and - 9.44vdc at the power rails.
During the q bias I was getting only 0.132vac at output. I started going through the troubleshooting list and got -1.337vdc to -0.776vdc at TP18 a little off but seems usable.
I measured 0.088vac at TP1 (little off), and then 0.017vac at TP15 (way off). I then grabbed my scope to try to figure out where the signal drop off occurs, and found it at the gate of Q1.
After reading the beginning of this thread I tried removing Q1 and the gain is vastly improved. I measure 3.63vac at TP15 and 16.45vac across output (ultra hot). I measured +12vdc at the gate of Q1 which also seems WAY off.
I've tried replacing Q1 and Q11 with spare 2n5457s I had with no improvement.
Let me know if you have any ideas of what to try next.
Hairball Audio said:Those GR amp outputs look fine to me. I would definitely get proper FETs, I'm guessing you have knock-offs.
Mike
Deejsirois said:Well, tried a set of matched FETs I got from you and still the same distorted signal when the gain reduction is turned on. I also replaced all the 2N3707 transistors in the GR control amp section just to make sure that wasn't the issue. I once again checked all the resistors in the GR control amp section as well as all the resistors on the ratio pcb....everything is correct. Need a new thought/direction to head in here because I am at a loss.
Hairball Audio said:So it works fine with no FET? Other than the lack of compression?
Deejsirois said:No, when I remove Q1 AND turn the attack on, I get the nasty distortion. If I put the Q1 FET in and keep the attack off, audio sounds beautiful. If I remove Q1 and keep the attack off, the audio sounds beautiful.
Hairball Audio said:That's nuts. So nothing sounds good with the GR ON, FET in or out. And you still cant get a voltage drop at your Qbias but you get a -1VDC to -1.7 (ish) reading at the gate?
Deejsirois said:Correct, nothing sounds good with GR ON. However, I can fully calibrate the unit...so we are at least good on that! Calibration went without a hitch, and I was so pumped thinking everything was golden....until I turned the GR on![]()
Hairball Audio said:Oh ok. So this is different than originally when you couldn't even calibrate the bias?
So everything calibrated normal, but in GR mode you have a lot of distortion? Re-check your Pad 22/21/CR2 voltages under calibration.
Mike
Hairball Audio said:Anode CR2?
