[BUILD] New FET/RACK Official Help Thread - Please read first post!
The power supply passed its test when I tested before the rest of the build. Knowing what measurements I should be getting at other test sites could be helpful though. I'll check that out.
NO, somehow I think I must have glossed over it. Looks familiar but I haven't read it so maybe I saw it before it was relevant to me. I'll definitely be checking that out. Thanks.
I’m assuming you’ve already seen this page, but just in case you haven’t, it is very helpful.
Interesting, the first thing it says is that, if your voltage is too low you probably have a problem with a transistor. The one thing I was worried about is the 2N3053 transistor. I seem to have burned the contact off while removing the one I messed up on (forgot the spacer) and wasn't sure it was going to work until I get it to my tech to repair the contact on the PCB.
When I test the PSU, first step - Set the ground in the screw-hole of the case then touch the red probe to the base where the green grounding wire is attached. It says I should have a reading of less then 1ohm. I have 2.4ohm
The new one I started building, thinking I'll just do better this time and somewhere along the line I'll learn whats wrong with the first, has a reading of 2.1
Is this a resistor that isn't soldered well enough? A cap? What is going on?
I wouldn't mess around too much until you figure that part out. What you're measuring there is the resistance on the path of your safety ground from the AC inlet, so you definitely want to make sure that's all squared away before you move on. Try probing around the area just a bit and see if that changes anything on your meter -- sometimes the connection is fine but maybe the probe is touching a bit of solder that increases the impedance reading slightly, or your black probe isn't actually in good contact with the chassis, something like that. At any rate, you do want to make sure that this path has as little resistance as possible since it is a very important one.
Thanks for the tip.
I suspect I've been having an issue with the solder doing what its told to do because of a ****** iron. More accurately, 2 ****** irons and a station that doesnt display the accurate temp.
Hello. I purchased a Rev F rack kit and appear to have been sent an incorrect part. I'm supposed to have a 7.68K resistor for R071 but didn't receive one. Instead, I appear to have gotten an extra 6.8K resistor. I've used my DMM and tested all of the resistors when doing my initial inventory, and then again to double-check.
Does anyone know if I can use the 6.8K instead at R071? I apologize if that's an ignorant question. I've put lots of kits together, but don't actually know much about the theory behind them. I reached out to Hairball, but have yet to hear back and I'd like to get this unit up and running for a big client project that starts in a few days. Thank you!
I'm guessing after a week of hearing nothing here or from other places I've attempted to contact Hairball, that I'm unlikely to get any kind of response and should try and track down my own 7.68K resistor locally if I want to get this thing up and running?
It was a holiday in the US last week, plus businesses were gearing up for all of the Black Friday stuff, so it’s not surprising that you didn’t hear back from Hairball.
I don’t have an answer for you about substituting a different resistor value there, but you could certainly just order the correct value from Mouser. If you want to avoid the shipping cost (since you’re buying one 10¢ part), see if you have a local electronics store, or barring that, perhaps a computer store that sells parts for arduino.
Will do. Thanks.
You might experiment with another resistor in series with the 6.8 k to equal 7.68k
Try like a few 82ohm or something close.
In a pinch I have found just the right combination to make it work.
By a few 82 ohm I mean grab a hand full of resistors close to that and measure them. You may be surprised you have the right combination.
Thank you for the help. I ended up ordering a few 7.68K resistors through a national distributor here in Canada. $1 for the parts and $20 for shipping, but what can you do? Need to get this thing up and running. Still no word from Hairball anywhere I've contacted them. Ah well.
Just in case someone else comes along with a similar issue at some point, this should be 820 ohms and not 82. (This post is more directed at that future person, so BruceARP I hope you won’t read this as pedantic, I think you just missed a zero).
You would add the values of the two series resistors together to get the total resistance (6.8k + 820 gets you relatively close to the desired 7.68k in this case. If you happen to have an 887 ohm resistor on hand instead of the 820, all the better). This would hold true anywhere you need to use two smaller resistors in series to substitute for a single larger resistor value that you don’t have on hand. Definitely a useful trick when you need it!
v2.0, got Qbias good voltages, getting audio signal on T1 pin8, but 0 VAC at TP1...
Anything I should be looking for ?
thanks
I don't recall the specifics in my case but I had what seemed to be a wrong resistor too. My response from Hairball is that it may have been a misprinted resistor (bands were colored wrong) but that, either way, it would work just the same.
I measured mine with two DMMs, and it was definitely the wrong value. Never did hear a word back from Hairball anywhere I attempted to contact them.
Okay, I found a hole in my testing regime. The XLR Input +/- terminals ARE shorting to chassis ground when and only when where is a cable inserted and that cable is connected to any other device. I'm going to try removing the jack and making an XLR F pigtail cable to attach to the board, and see what I get.
EDIT: I tried that, and it made no difference, so the issue is definitely somewhere on the board that's beyond. Shipped it to Mike at Hairball today, and I absolutely cannot wait to find out what happened here.
Any word on what you found out? I have the exact same issue.
