Hello!
I recently put together a Rev A kit that I purchased a few years ago (PCB V1.12 - newer plug/play PSU) and I'm having low audio output issues.
Basically, build went fine - PSU checked out with +30VDC and -10VDC at respective points, device does input and pass signal, however, when attempting to do the very first calibration process (Qbias), I cannot output more than 1.2~VAC, not even close to the requested +11dB/2.75VAC (input set to .775VAC, Input knob set to 24). That's even with the output knob completely cranked/zeroed.
I went to the troubleshoot section of the Hairball site and started testing.
First test was for QBias Voltage - Requesting -1 VDC to -1.78 VDC at TP18 when setting QBias trim from mix to max. I did pass this with accurate voltages.
The next test requested setting the input knob to read 0.100VAC at TP1, and then check Q2 Gate, Q3 Base, and TP15. Q2-3 and TP15 were all very low voltages.
So this points me to the output circuit then? I guess my question is, where do I go and what do I look for from here? I'm currently double checking transistors and for cold joints, but nothing seems too obvious.
Lastly, unrelated, my meter does not seem to move at all. I'm assuming it's damaged? It lights up but that's it.
