lolo-m
Edited first post with diferent links and soundsamples...
Eddie, is that what you're looking for ?
Kingston said:Regarding bigger and more flexible networks,
how do you suppose it should be handled, when there will be significant amounts of LARGE film caps for each channel?
with the possibilities you listed there combined, it's going to be one FAT time constant expansion board in an already cramped space.
Yes, I had a look at the TC part of the GSSL... The TL074 isn't a really powerfull op-amp...radiance said:Lolo, just checking weither I understand your side chain booster.
Higher voltage in the side chain means that the caps that handle the attack time can recharge faster (or that you can use different value caps that do).
Soo, can this concept be applied to the GSSL side chain as well so we can have ultra fast attack times?
Or can the VCA's not generate them?
lolo-m said:I don't know if the VCA can handle ultra fast attack times so I can't say it'll work or not ???.
radiance said:I think there will be distortion with faster attack settings. Did some tests with the fastest available attack and release and when compressing heavily I got some distortion in the low end. Faster will probabely be worse...
radiance said:Well, that Vertigo VSC-2 has the exact same attack times as the ssl...I would have expected something faster....
crisotop said:Printed on the panel, it feels a lot faster (not sure if the ssl timeconstants are correct)
Do you have a problem with mods done on your stuff ?analag said:Good God...It's time to release my ultimate Mu Compressor...the mind blower...and if you want sound samples I will have my man Volker host some serious crush, attitude, color, tube sound...fer yah. Seriously I don't want to give out that one.
lolo-m said:Do you have a problem with mods done on your stuff ?analag said:Good God...It's time to release my ultimate Mu Compressor...the mind blower...and if you want sound samples I will have my man Volker host some serious crush, attitude, color, tube sound...fer yah. Seriously I don't want to give out that one.
I thought we were in a DIY forum :... Or maybe my poor english is a problem to understand what you mean...
Here it is ! On first post ;D...SUPERMAGOO said:you could do some tests with drums?.
I would like to hear the different mods with Buss-drums or just
bassdrum+snare.
eso lo grabaste en españa? saludos!
Did I understand you correctly? You had a hum issue caused by filament supply? Did you solve that? How?This is out topic, but have a look with a scope at what's happening in the filament PSU. Push-pull technology is meant to cancel filament hum problem, but in mine it isn't Cry...
Yes, you did understood correctly.Moby said:Did I understand you correctly? You had a hum issue caused by filament supply? Did you solve that? How?This is out topic, but have a look with a scope at what's happening in the filament PSU. Push-pull technology is meant to cancel filament hum problem, but in mine it isn't Cry...
