lolo-m
Moby, lightening fast, as ever
Updated 1rst post with new wiring guide
hehe, "SCAB MODE", sounds awfulCan't wait to hear the scab mod!
dagoose said:Is it correct that the -17v and ground to the PM boards are both disconnected? i can imagine the -17v but the ground= earth or am i missing something here?
dagoose said:I dind't realize that the 10uf on the scam board is replacing one 10uf of the PM board.
I have wima's on the PM boards but i have a cheaper epcos poly cap (191-2948 RS) installed on the scab and so i'm wondering if it's better to desolder the wima and stuff it on the scab board.
It will be a bit harder and a lot more work because the wima's are a lot higher then the epcos caps and i have to put the scam board on a different place in the case. Now it fits above my XLR connectors with the transistors isolated mounted to the case. So.. will it make any difference if i use the epcos?
dagoose said:Is it a problem if i leave the discontunued 10uf wima on the pm board or shall i remove it anyway?
lolo-m said:Kingston said:you still definitely need the -17V wired to the main board! You will wreak serious havoc if you remove the connection.
It is used to bias the many tubes of PM.
Note that +17V is not actually required at all in a plain poorman. You don't really NEED relays and light, and meters. they are just luxury.
[edit]
ok... looks like i missed this (how could i..) and saved the wrong, old, wiring guide. :-\
I think that after the weekend i will have it done!
now that I look at it, isn't there an error on the SCAMP wiring guide? the -17V connection is missing for the main board.
[edit2]
and ground!
Yes, there's two missing wires on the wiring guide ;D. It was an evidence to me, but I agree it isn't !!!
The PSU feeds the PM660 board with GND and -17V and SCAB Board with -17V/GND/+17V.
Hi Eddie,SaMpLeGoD said:Hello,
Just some rookie's questions... what's for that two 4k7 trimmers on the SCamp board? How can I regulate them?
Eddie ???
lolo-m said:SaMpLeGoD said:Hi Eddie,
Set the 2 PM660 boards trimmers as described in the 660 support thread.
Then, switch the SCAB in analag's mode.
Measure the voltage between the 2 pins of the SCAB "TO ATTACK-X" connector. Set the 4K7 trimmers to have 0 Volt there.
Here it is, the SCAB is set and ready to play in both modes!!!!
Hello Lolo!
Thanks for the explanation! I already did it!
I had a problem in on of my channels before I install the SCamp PCB, and I still have it with the board installed...
One channel compress, normally, althrough some strange behaviours in the extreme positions... but the other one, has some problem in the main board... still don't what what is happening...
With the new board (SCamp) I feel more the compression... but everything is still light to me... I didn't put that 75Ohm resistor that u said on your "pimpin' my pimp..." Will it rise my attcack to 0,4ms as I read? as long as I have some 2.2uF caps on it?
I really will love to have my compressor all working... but so far have some problems to solve...
Eddie :-\
SaMpLeGoD said:Thanks for the explanation! I already did it!
With the 75 ohm resistor added, you'll have about 0,2ms with 2,2uF on the SCAB board and no other cap paralleled. To have those 0,4ms you're talking about, you need to have the 2,2uF on the board and another 2,2uF parralleled on the TC switch.SaMpLeGoD said:With the new board (SCamp) I feel more the compression... but everything is still light to me... I didn't put that 75Ohm resistor that u said on your "pimpin' my pimp..." Will it rise my attcack to 0,4ms as I read? as long as I have some 2.2uF caps on it?
Eddie :-\
dagoose said:dammit... the scab board turned out to be a crap mod.. :-\
Both channels have distortion like hell, one channel is blown up in some kind of way (think the 6107 transistor, not sure) and everything is connceted the way it should..
Removed the c4, bridged it, removed r18, bridged it and removed all 4148's on the pm board but shouldn't there be some kind of bridge in there as well?
So far.. it sucks big time, i had a working pm670 but now it's dead..![]()
lolo-m said:Hi Eddie,SaMpLeGoD said:Hello,
Eddie ???
rrs said:lolo-m said:Hi Eddie,SaMpLeGoD said:Hello,
Eddie ???
Just checking if when measuring between the two attack pins the Attack switch can be disconnected (for easier measurement). I ask this because it was mentioned in the 660 support thread that all connections should be made when firing up.
I don't understand what switch you're talking about :-\. To me the SCAB "TO ATTACK-X" is a connector with 2 wires connected to PM660 "ATTACK" connector. There's no switch there.rrs said:I only meant disconnect the "To Attack X" switch.
It's these two pins that should measure 0V between them right. Is it safe to disconnect the attack switch connector to measure the two pins?
lolo-m said:I don't understand what switch you're talking about :-\. To me the SCAB "TO ATTACK-X" is a connector with 2 wires connected to PM660 "ATTACK" connector. There's no switch there.rrs said:I only meant disconnect the "To Attack X" switch.
This connector MUST be connected. The link is necessary to acheive proper setting.
The only switch I see is the "MODE" switch and it must be connected too to toggle the SCAB into analags mode (anyway, it wouldn't help to have this one unconnected).
Check back the wring guide and use the labels you see on it. I will answer more clearly to your questions.
Pin 3 should be on ground but 2 no. Desolder the 7812 and check did you shorted 2 pin pad somewhere to ground and check 7812 too . I presume that you made some soldering mistake somewhereOne thing I noticed was the LM7812 pin 2 and 3 both seemed to be connected to ground. Does this seem right or do I have a faulty component?
Moby said:Pin 3 should be on ground but 2 no. Desolder the 7812 and check did you shorted 2 pin pad somewhere to ground and check 7812 too . I presume that you made some soldering mistake somewhereOne thing I noticed was the LM7812 pin 2 and 3 both seemed to be connected to ground. Does this seem right or do I have a faulty component?![]()
