bernbrue said:Yes, you should mount it with isolation on chassis, otherwise it will get very hot and turn into thermal shutdown (-> no heater voltage).
Bernd
Noted, thank you...bernbrue said:You need a TO-220 voltage regulator.
Bernd
bernbrue said:You need a "momentarily off" switch, i.e. when pushing the switch, the contact to ground is interrupted. This causes noise , which is taken as a kind of test signal in order to balance the two 6ba6 tubes and the two halves of the double triode output tube.
Bernd
kosi said:I installed the U-pad followed by a T-pad attenuator from CAPI and the first tests are perfect.
The output works like a "normal" compressor, e.g. I have Input and Output at 12 o'clock and the volume is about the same bypassed and compressor engaged.
I used 1/2 W resistors and the CAPI T Pad Adapter, I attach a picture.
Regarding my relay problem: I connected my relay as you said, but the problem remains....
bernbrue said:Hi Hugo,
where did you use 82R instead of 68R. I don't know what you are referring to, power supply, main board?
In case your 5V rail doesn't give you enough power you can connect the relays to the heater supply.
Bernd
