bernbrue
Well done! Very nice build! 8) ;D
Bernd
Bernd
techineer said:Are there any specifications for this version, or are they the same as the original Gates unit?
I've been reworking a build that was done by one of the members of this group, and after getting it (apparently) working, it seems to require a very high level input signal before compression occurs, resulting in a very high level output.
I'm wondering if it really is working properly, or if something else needs to be diagnosed.
Beginning around message #220 and possibly some others is mention of a problem in the +5V supply. This unit was sent to me to iron out the bugs, and I see what is probably a design flaw in the 5V supply.
The secondary winding for this supply is 5VAC (measures 5.6VAC RMS) After rectification it should measure up to 6.7VDC (or less, depending on load) (5VRMSx1.414 (peak) -1.2V (Diode drops)). The LM317 requires at least 3 volts greater input voltage than the desired output voltage in order to maintain regulation, or more as the load current increases. http://www.ti.com/lit/ds/symlink/lm317.pdf (See page 9.)
In order to have a regulated 5 volts output, the DC input voltage must be at least 8 volts and preferably more. The AC voltage required for this is at least 6.5VAC. ([5v out +3v (reg I/O diff) +1.2V (diode drops)]/1.414 =9.2v/1.414=6.5VAC rms) I would suggest another 9V winding instead of a 5V one.
You could also jumper the 9VAC input from the filament circuit over to the 5VAC input, as there should be some excess capacity in that winding. The tube filament current ratings add up to 2.1A, while the transformer winding is rated at 4A. The 5V regulator is limited to 1A, so that should be usable.
