I have finished my Sta Level after nearly a year. A very good sounding Compressor, phat, especially on Vocals...! Mine one is with Sowter InTX and Hammond OutTX, NOS Philips 6BA6 tubes, I ve used a cheap TR-76 from AliEx and printed the Meterscale from the thread on the Inlet. Looks really good! Frank from frontpanels.de has done the frontpanel on anodisised Alu.
I had Issues with the PSU, DjFatum helped me to get this PSU working - thanks man!!!
Some experiences I want to share:
- if you want to use a TR-76 (Simpson looking) Meter - the Standard R7S Resistor with 68 Ohm is correct, if using a TR-57 (looks like the Sifam Vintage Al20SQ) you need to increase this Resistor to 100 Ohm to get in the Range for Calibration of the Meterzero
- R3 only with 3W like mentioned in the BOM - it is to less! - it should tweak the Voltage from ~400VDC after the Rectifiering Diodes/first Cap to about ~300VDV -> I ve used a 1K Resistor for this 100V Voltagedrop. So this HT Rail pulls about 0,1A
- 10W Power > I really recommend for R3 a 50W Resistor!!! Then this Resistor gets only warm, not hot - mount it on the case ... The Resistance of R3, as said, depends from Voltage after the Rectifier - before R3. And if your Power AC Plug gives you 220VAC, 240VAC or 250VAC the seconday AC also can be higher or lower.....As further Example if you have about 420 Volts before R3 you need to tweak about 120V down to about 300V - that means -> use for the pulled 0,1A - HT Voltage Rail a 1K2 Resistor with over 25W for R3. If the HT Voltage is then correct after the HT Regulator with about 300V the Bias Voltage should also fit with about 100V.... Correct me, if I am wrong. But its logical..
- my first Terroid PSU was from DONs - audible hum and vibrations like hell, the 5V AC rail Voltage also was way tooooo low for usage, only 3,7V after the Regulation. .... So I ordered a stronger new custom Terroid with 120VA (Pri 230V, Sec1 300V 0,2A, Sec2 8,5V 8A, and Sec3 7V 1A, electrostatical screen) from Audiophonics France, 3Months waiting time - about 90 Bucks incl. delivery in Europe. Perfectly...
-and I really recommend a good TO220 Insulator made of Cermic!!! for the LM338 Heater/Filament 6,3VDC Regulation mounted on the case. It emits the most heat of all components in my case. And I had a tricky shortage with the 338 Regulator to the case there...
All 6 Tubes (using the 6BA6 Tubes) are pulling about 2,1 A at 6,3V Filamentvoltage!
Thank you Zayance and Bernbrue for this great work!!
