fallout
FarisElek said:I poorly photoshopped one for myself and it's working out fine on my Drip build. If anyone has a better one you should probably use theres but in the meantime.
Thank you! It doesn't look bad at all.
SKJGProject said:will try to work on this in 2020....anyone wants to share his mouser cart/project?
SKJGProject said:anyone?
I don't know if this will relate to the designations on your build, but check your R37/C11/switch, etc and make sure they're doing what is indicated on the original schematic. I had this exact thing in a build where there was a cold joint in that section.Dr_J said:Then I measured again and the good news was that now all values are stabile
But some are still high out of range. Something to worry about?
The noise level is still not satisfying:
-75db@50Hz (Output fully ccw, SLOW MODE)
-57db@50Hz (Output fully ccw, DOUBLE MODE)
-57db@50Hz (Output fully ccw, TRIPLE MODE)
The DOUBLE MODE shows a repeating pop/hum sound. (No audio in)
It's starts at input around 9 o'clock, frequency increases when input turning cw,
>3 o'clock it disappears. Similar behavior on TRIPLE MODE.
Power transformers do that.Dr_J said:My power TX gets hand warm, normal?
Great to hear!Dr_J said:Thanks to Bowie, I re-soldered some joints from BOTH sides of the pcb!!
Now it's quite.
Noise Level on all Modes now around -95db@50Hz ;D
(Not sure if it now works correctly, changing the modes seams to make no big difference...)
Hey Dr!Dr_J said:Hi IanB,
I'm not good in remote diagnosis... but maybe some simple hints would help you to keep going...
Did you remove all the mods for 6386!?
As on mine I would check (double) the two control boards!?
Bernd has described some good trouble shooting tips in this thread, have a look.
(I found out later that my "LOG Output Poti problem" has been described already)
ROCK-ON!
I used the CAPI/hairball output attenuator. Works, or should I say “worked” great....until I pulled it all apart.Dr_J said:I'm still struggling with my output pot... :-\
Now I'm a bit confused... the BOM calls for a 50k LIN Pot, the MOUSER Part-No. points to a 50k LOG.
The original schematic (i have) shows a 1k...
Looking at my output curve, it looks like a 7k pot will nicely fit...
What have you guys used?
ROCK-ON!
