Meanwhile I'll ask this again if you don't mind-
Sorry, I dont have any real time frequency response measurements available.
I set my tone generator to square, and read the frequency on my scope.
Gustav
Correct. I should have searched the thread, but thanks for answering this question again.Is this with no tubes installed, as your picture would suggest?
If so, consider for your findings, that (I) with no tubes installed is significantly lower than (I) with tubes installed.
Gustav
For the attentuation not working - try different frequencies. Theres a cap setting the value of each, and if all but one/most/even just one is working, the problem is those caps not making connections.
Maybe the switch is stopped on the wrong side for the frequency select, if its all of them. To check, take out the stop-pole, turn the switch all the way counter clockwise, and insert the stop.
Finally getting around to some serious bench testing...I had an issue where I mis-wired the IO to my patch bay when first trying to pass audio. After sorting that out I was able to get the left channel working. I opened it up and found that if I moved the tube around in the right channel I could get it to go in/out. The top/bottom assembly is a more loose in that socket than the left channel so not an ideal scenario. I switched the drop resistor to 20K so that the high voltage wouldn't exceed 250v in the event that the right channel tube socket craps out but with both channels active these are the power calculations.
The right channel's output is quite a bit louder than the left channel even in bypass mode so I took DC voltages at the tube socket pins to ground.
These all look consistent except for the heater voltages at 4 and 5 but when I measure DC across the pins I am getting 5.7v so that seems expected.
I switched out all cabling across the channels, even the internal wiring from the board to the XLRs and it all points to something on the main board.
Could it be the output transformers aren't matched? Or could the left channel transformers have been damaged while the IO wiring was incorrect?
I swapped the tubes and re-flowed all of the solder joints on the main board before swapping out drop resistors.
Should I take voltages at the output transformer pins next?
BD
There is a difference of about 12.5dB attached is a pic of a square wave going into each channel on bypass and recorded back into pro tools. I did try swapping the tubes.1. How much is "quite a bit louder". This could be 0.3dB or 10dB, depending on the person speaking, so its easier to help, if you are specific.
2. Did you try to swap the tubes to see if the discrepancy follows? The raw-tube gain will differ.
3. If its in the 0-2 dB range, I would tell you to replace the last resistor step on the high cut attenuator with a trimmer and adjust.
Gustav
I tried plugging the XLRs into each other and I got consistent levels across the channels at -12.43dB.I would start by bypassing the filters - the 3 pin connector spots going from the main board to the filters - if you disconnect those, and place a jumper from 1 to 3, the signal path will be isolated to the input, gainstage and output.
If the 12dB difference remains, it will be limited to a very small area.
And, try plugging XLR in to XLR out directly on the cables to make sure this is related to the unit, and not something else int he set-up. I dont know how common it is for you to use outboard, but many errors have been traced down to these types of routing problems, a fader set differently in an interface mixer, etc, so best to check
Gustav
Thank you. Yes, I did notice that. I left the unit alone for a couple hours, removed the tubes, and turned it back on. The heater voltage is back so I put the tubes back in and now I am able to pass signal on the right channel. The level -1.68dB is consistent with the left channel when the filter board is shorted.take care - the high voltage gets really high and stays for a long time when there's no heater to make current flow
Yes overtones are to be expected and in most cases also desired. If you use a Pultec style EQ you wouldn't expect it to be clean...After a long break, I got my EQ over to the studio to audition it. Sounds very good! A few questions:
1. Pro-Q screenshot is a 1k tone being sent from Pro Tools, with the EQ in bypass. Are the overtones expected? They're in both channels.
2. The LF attenuate is much more aggressive than other Pultecs I've used. It's noticeable right away, and the boost/cut trick seems happier with the cut at 1 or 2 at the most. Do other folks experience this?
3. I misplaced a red knob cap. Anyone have a part number that I can hopefully get in the US? (btw I quite like these knobs)
I also noticed this behaviour on the LF attenuate control when I first tested mine. It's just a matter of how the log curve of the pot looks and these can of course differ. I did mine with stepped rotary switches so I changed the values of the resistors, but still hardly ever use it above 2 or 3.
Sure, but I was surprised by how loud they are. I'll test on a friend's Pultecs soon.
Mine is the stepped switches & resistor values that came in the full kit from Gustav. Glad it's not just me at least.
