bjoneson
Alright... I'm trying to wrap my head around some theory stuff.
Let's take a simple case...
Passive summing bus. 24 channels with 10k bus resistors. Inputs (high side of bus resistors) are fed via opamp to a SPDT assign switch. (Legs are opamp output / ground, common is high side of bus resistor).
I think I understand the bus impedance / loss part. 24 channels of 10k bus resistors yields a bus source impedance of (10k / 24) Apx. 417 Ohms.
Bus gain (loss) is therefore (417 / 10k) Apx. .042 Assuming the bus is feeding a high impedance input like an opamp input, and ignoring the NFB load (if any).
Ok... so here's where my understanding of theory breaks down. All that makes perfect sense when the channels are in the off position. That is, with the high side if the bus resistors switched to ground. The bus source impedance is literally impedance to ground in that case.
But when the channels are switched on, the high side of the bus resistors are now connected to an opamp output. I understand that in "theory" an opamp output has a near zero "source / output impedance". But is this actually an impedance to ground? An ompamp has no concept of ground. Why do we get to treat the output of the opamp as equivalent to a low impedance path to ground (or I suppose 0V)?
Maybe I just kind of answered my own question. Am I understanding correctly, or am I missing something?
