Potato Cakes
Hello!
I've built mine up to the point where I have mounted transformers and I've come across some issues/discrepancies that might be of note.
First, the 470uF Audio Capacitor listed in the BOM is actually a Low ESR and is fairly tall, but I believe that it will be within the one slot space. The Mouser part number for the audio grade version is 647-UKT1H471MHD (if you want 105C instead of 85C). This probably won't make any audible difference either way, but one should be made aware if they are absolutely wanting a particular capacitor for C61.
Second, the 250k potentiometer on the BOM for the Attack control is physically deeper than the 10k pots. This causes an issue when mounting the boards to the faceplate as it overlaps with IC7, preventing it from being flush.
I also forgot to order the 1M pots and the correct 1uF caps with the 7.5mm lead spacing. I don't have enough of the 5mm ones for all four of the modules, so I might as well order the correct ones with the proper physical dimensions. I was hoping to have these up and running this week. Another box from Mouser just showed up so I guess I'll work on some other projects I have awaiting.
Paul
Paul
