The first problem I had is that at first the EQ didn't work when engaged. That was because I didn't (I don't know why) wired 0v in the PCB output to XLR pin 1. I understand I had no sound because the entire audio path didn't have a 0v reference, could that be correct?
Once I wired that, all was good. I tried to check the boosts and cuts and they all work, minus the High Mid of channel one (it goes up to around 2kHz and no beyond). There's some click and resistance on turning frequency potentiometer, so I'm assuming it is broken. I'll replace it and I expect it to be OK.
And lastly, but this has me puzzled... Bypass LEDs are not working. From what I gather from the layout, pads correspond to Green - 0v - Red, but I can't make this to work. This is the LEDs I got:
https://www.mouser.es/datasheet/2/244/lumex_lumx-s-a0001355871-1-1737718.pdf
If I wire the center leg to the center pad on the PCB, it doesn't work at all. Checking with DMM, center pad has -14.6 V referenced to 0v on the supply, so I understand center pad is NOT ground, right?
Anyway, if I wire the center leg of the LED to the right pad, I have the LED lighting up but only in the leg wired to the center pad and only when the switch is ENGAGED.
With switch DISENGAGED, I have no lights at all. Voltages on the LED pads are as follows (measured in reference to supply's 0V):
ENGAGED
Left Pad 0V
Center Pad -14,6V
Right Pad +14,5V,
DISENGAGED
Left Pad +14,5 V
Center Pad - 14,6 V
Right Pad 0 V
I'm quite certain that this should be easy, but I'm kind of blocked... Is engaging the swtich changing which pad is Ground? It doesn't make any sense (to me, but I know next to nothing...). I tested the LEDs before wiring them, and they worked correctly, and the Bypass switch is working so I'm quite lost about what could it be... Any ideas?
Also, for the Power switch LED... Is it OK if I wire it directly to the PSU or would it affect negatively to the PCBs supply? (I suppose it won't, as it shouldn't be a lot of current)
Thank you all for all the knowledge shared along the years and specially to Jakob for making this awesome circuits!
Cheers all!
ENGAGED
Left Pad 0V
Center Pad -14,6V
Right Pad +14,5V,
DISENGAGED
Left Pad +14,5 V
Center Pad - 14,6 V
Right Pad 0 V
Cheers all!
