SPG
Member
Hi guys/gals,
A while ago I picked up this interesting 7 channel EQ unit made by the DGC Hare company sometime in the mid 50s (I believe-a piece of masking tape on the top indicates it was calibrated in 1958!). From the research I've done, pretty much all I can find out is the DGC Hare Co. went on to become Grass Valley. It has a single 1/4" jack for each channel and because of this small detail I've made the assumption that this unit was most likely part of a modular console setup, designed to be inserted between the input amp and the channel output or possibly into the feedback loop of the input amp itself (kind of like the UA 508 worked with the 1008 and 1108 units). Each channel has a 5751 and a 5814A (a 12AX7 and a 12AU7, more or less), along with a Triad A-55J output transformer. I'm dying to get this thing up and running, and was hoping one of the many minds here might have some helpful info or ideas for me as the internet is completely devoid of anything useful. Granted I can just build the power supply and start dicking around, but I figured ask around here before I started that fun process just in case someone knew something. Anyway, here's a few pics:
Anyway, thanks for taking a look at my post. Any help or info from you guys would be greatly appreciated.
