Ive had very stable results using a variation on the B&K CF preamp circuit ,
even the unbalanced CF out makes it 15feet down the cable without degradation or noise pickup ,through the HPF and matches into 1M very well .
As I have the balanced topology in the pre the impedence balanced noise line makes even more sense .
It does make the HPF twice the trouble to do ,
I had done it simply before with a single rotary wafer switch but you end up with the extra incidentals of all the caps hanging off the line , dual wafer is better ,but if you then have to balance the the negative 'noise' input your upto a quad rotary switch assembly .
Ive done a basic 12 step HPF , its really effective for dialing in the low end on mics with proximity boost , caps dont need to be large or have very high voltage ratings as theres already a larger DC blocking cap and bleed resistor beforehand ,
A 23 step symetrical HPF using a 4 gang wafer , SMD chip caps might be an option but I used the small Wima red box caps before and they fit nice and neatly,
The Baxandall mic HPF circuit varies the coupling cap from around 0.1uF to around 800pf into 1M .
Any good coupling cap calculators that allow you overlay the various response curves of the caps ?
This one looks handy ,
https://www.ampbooks.com/mobile/amplifier-calculators/coupling-capacitor/calculator/
Handy video this one, its a very fast intro Kicad and it does just the very thing I wanted , Ill have to pluck up the courage to give it a go ,
