There are plenty of online coupling cap calculators , some will even present you with the FR graph but they generally dont offer the component value on a slider with fast auto recalculate after you touch the control , instead your stuck typing numbers in boxes . Maybe theres a simple way to overlay the screen shots to build up a better picture of how a switched HPF would look .
The idea of using a cathode follower as the drive for an impedence balanced line came to me in my dreams the other morning , I half forgot then bang the light bulb flashed again .
Re-doubling my efforts to make the HPF fully balanced makes loads of sense , as it means I also have the option of running balanced sources to the output stage , the fact that every thing in the output stage is then symetrical , incuding the path to input grids should mean any PSU induced hum is very effectively canceled in the output transformer .
The other idea I had was the possibility using both grids to mix two unbalanced signals into a single output .
The output stage is based around the BBC standard ECC81 circuit used in their equipment of a certain vintage , notice the boot lacing on the grids /cathodes .
Id add a parallel fed output transformer to this set up so the theres two sets of outputs ,
The other interesting point about these pre amps is the PSU is very simple ,theres no local decoupling on the HT where it hits the OP TX's centre tap ,
Full details here ,
https://www.bbceng.info/ti/eqpt/C_9.pdf
Full details here ,
