Channel Linking of Sidechains
hagtech
Hawaii
Is there a common practice for linking sidechains together for compressor channels? I see a lot of stereo or two-channel compressors have the ability to link, and hence compress equally both channels together. But what about linking to other boxes? Is there a standard connector for this?
I'm thinking of either RCA or phone type. Or must everything be XLR in pro audio?
jh
Different make/model compressors?
No, because:
1) every compressor has a different control law. How would you link the LA2a opto, with a quasi-linear control law, to a dBx with a mV/dB control law, or a dBx to a Fairchild with a roughly 2V/dB control law? Some swing negative, some positive. Most drop gain when control voltage rises, but some idle at a voltage that falls toward zero to reduce gain. Sure: amplify, attenuate, and function-generate, but it gets ugly too fast. Even linking two "same" control elements is dubious unless they are exact (dBx et al) or painstakingly matched. You can sell mono FET limiters with +/-2dB tolerance, but to sell them linkable without image-shift you have to match ALL units to better than a dB, which means throwing-out a lot of perfectly good FETs or doing a lot of fiddly trims.
Why would you want to? In my little world, you have mono limiters, and stereo limiters, the latter sometimes being two monos lashed together. If I want two limiters working together, I probably want two of the SAME limiters working together, and whatever linking they use is OK by me (as long as I don't have to buy an expensive special cable). This would extend to quad or 5.1 7.1 systems: you use 4, 5, 7 of the same thing.
Hmmmm... there is the different case of "ducking", or inverse linking. Background music in the supermarket should "duck" when the manager makes an announcement. Such things are normally done in one box, but large conference rigs may be multiple 8-in mixers with shared bus and linked over-ride. Still all one maker's system.
2) no compressor maker wants to co-operate with the competition.
If you make both boxes, and they are adjacent, I don't see why not. Except that economics often suggest, if you need multiple channels, you put them all in the same box. There are several stereo and at least one quad limiter that can be run split or joint, with just a switch. If you are doing a dozen-tube limiter, you may not get two in one box, but even the mighty 670 was packaged as one box though built on several chassis (I think).
Back when dinosaurs carried screwdrivers behind their ears, and every tech could terminate a cable properly, screw-terminals were common. Sand-state limiters only put 1V or 10V on the CV node. The Fairchild could do 50V, but even that is not grossly unsafe, and would only happen when the levels were slammin'.
[quote author="PRR"]
[/quote]
i often wondered about these, especially about the way how the different signals are mixed together according to its priorities.
<multi channel side chain link>
regards, max
I realize this is not along the lines of what you are asking, but...
The standard practice for linking compressor sidechains of different manufacture is to mult the audio that you want to be the control source and feed it to all of the side chain inputs you want to control.
This is, of course, not "linking" per se.
i´m interested in possible algorythms controlling cv from more than one source-and for more than one destination. one application would be some kind of active summing with 8 interacting compressors controlled by 8 channels of threshold-every signal could affect the other...
