I would try a good 3819 instead of the 170 and add a 1meg bias trim
I bet you're right. I can't imagine they're using capsules that could handle a steady 76v.No guarantee that the full 76.2 V. will be on the capsule.
I mention this, because I see four 51 M.Ohm resistors on the PCB near SW1.
Sometimes they split the voltage in a multipattern microphone.
(See attachment.)
Sounds like maybe they should be called Smellinfunken!I don't like Telefunken brand name owners (whom have nothing to do with historical Telefunken) rebranding chinese microphones and selling for 10x the price making false, indirect connections to Neumann and others by exploiting couple of numbers and letters.
Vintage Telefunken mics were more less rebrands of AKG and Neumann which is no longer the case. Hence i don't see much value even in modern Telefunken u47, elam, c12 models they sell. They are not worth a dime above the sum of the parts they used. Modern Telefunken is a rip-off of the European heritage. And the fact capsules, transformers in higher end models are made in USA doesn't help either, as it's yet again just a rip-off of the originals without any consent from the original manufacturers. Just exploitation of expired patents. High end Behringer business model.
Austrian Audio is something else, there's no chinese clone besides couple which roughly cosmetically resemble the AA ones.
