Class A stuff from EW+WW
[quote author="mikep"]what kind of FET is Q3?[/quote]
MOS, since a resistor from pot to ground present. In case of JFET this resistor is not needed, but minimal output voltage will be higher You may use a BJT with as high beta as possible to decrease a base current for better voltage regulation.
Strictly speaking, "Imax" pot does not set max output current; it sets max power dissipation on the transistor when output is shorted so may be adjusted once depending on it's beta (max resistance, ampermeter from output to ground, slowly adjust max current).
[quote author="Wavebourn"][quote author="clintrubber"]
But OK, on to my point here: it also made me wonder if it'd be possible to have a thread with posted circuits that everybody 'agrees' on... (FWIW, but just curious)
So no further improvements possible (without going overboard w.r.t. component count, dissipation, voltage rails, board space, esoteric parts etc), in three words: blameless, perfect, elegant. And to keep it 'unbiased': preferrably from someone else than the submitter. Any circuits that come to mind ?
[/quote]
Here you go: class A output stage. Single point input, overload protection, symmetrical and linear, wide bandwidth (I used b-c junctions instead of diodes).
Actually it is made of 2 complementary opamps loaded on each other, connected as voltage followers. Diodes instead of transistors are used because b-e breakdown voltage is usually very low (I saw only one transistor that had nearly equal b-c and b-e breakdown voltages, but it was a small signal one).
Can you improve it (except current mirrors instead of resistors between b-e of output transistors)?[/quote]
Interesting & funny, was first taking it for two CFP-stages, but then understood those diodes are in fact 'doing' the right BJT of a LTP.
So I figure the thing would work also without the diodes but dunno how/if performance would drop.
W.r.t. using two of these mirrored on top of each other, is everything clean around the midpoint ?
For push-pull I'd be more inclined to something like this below but admit right away that I haven't done any comparison w.r.t. performance of one of the other.
http://www.dself.dsl.pipex.com/ampins/discrete/cfp.htm
Regards,
Peter
[quote author="clintrubber"]But OK, on to my point here: it also made me wonder if it'd be possible to have a thread with posted circuits that everybody 'agrees' on... (FWIW, but just curious)
Regards,
Peter[/quote] Perhaps I'm just in a pessimistic mood today, but I was looking for one of those emoticons where the guy is laughing hysterically and pounding the ground...
[quote author="bcarso"][quote author="clintrubber"]But OK, on to my point here: it also made me wonder if it'd be possible to have a thread with posted circuits that everybody 'agrees' on... (FWIW, but just curious)
Regards,
Peter[/quote] Perhaps I'm just in a pessimistic mood today, but I was looking for one of those emoticons where the guy is laughing hysterically and pounding the ground...[/quote]
Yeah, I should have known better :wink:
But then again, not everybody might agree with that statement either :twisted: :green:
[quote author="clintrubber"][quote author="Wavebourn"]
[/quote]
Right. If I had transistors with high B-E reverse breakdown voltages I would probably use them instead of diodes. Overload protection means high voltage on them when output is shorted. Interestingly, it sounds "tubey" as people said, probably because of very soft clipping! The drawback is, resistors in tails has to be selected and their values depend on beta of output transistors. Fortunately, I had then already selected transistors with beta = 100 and CE breakdown voltages = 200.
No, without diodes you will need some bias adjustment on bases and some temperature compensation. Also, an output protection against high power dissipation will be lost. Without diodes you will convert operational amplifiers to voltage followers. You'll be not able to operate it in such an elegant class A like in my case; you'll need twice more of a quiescent current to operate in class A that means more heat per output power. Actually, my version is the way to kill many ducks by a single bullet. It is a power amplifier, not a voltage follower that tries to compensate non-linearities of a current amplification by 100% feedback.
On top? What do you mean? It is already symmetrical push-pull amp. I used 2 of them for a bridged output configuration (a speaker cabinet had something like 16 or 32 Ohm impedance, I don't remember). I took inputs from the same phase splitter that used to drive output tubes.
In case of tubes such a follower works great, but you should remember that a resistor on top converts current to voltage that feeds the bottom transistor that needs a current to operate more linearly despite of a resistor in it's emitter that improves things. A MOSFET would work better there.
One more drawback is, the bottom transistor provides phase - shifted current variations.
I have a better version of such approach when a voltage follower is loaded on a voltage to current converter. I can share it with you if you want.
