It was designed using the free frontpaneldesigner software provided by Schaeffer on this side of the pond. They have an associate company on your side that will make the panels from the same design. I have attached the fpd file for the panel. You need to rename the extension from txt to fpd and load it into frontpaneldesigner, From there you can export it as a dxf file. As I wrote that I realised I could just append the dxf file instead so I have, lol.That panel layout looks like something I could help with, Mr Ian. Do you have dimensions to go with it?
While I was able to easily import your DXF file into FPD, I received the following list of errors:It was designed using the free frontpaneldesigner software provided by Schaeffer on this side of the pond. They have an associate company on your side that will make the panels from the same design. I have attached the fpd file for the panel. You need to rename the extension from txt to fpd and load it into frontpaneldesigner, From there you can export it as a dxf file. As I wrote that I realised I could just append the dxf file instead so I have, lol.
[if my forum etiquette is off please inform me. I'm new and don't wish to offend] -- Don't worry about this, but just be aware of the fact that.....while you are on this forum posting your comments and responses, it doesn't matter how cordial, nice and/or pleasant that you are in your writings, at some point-in-time.....SOMEBODY ON HERE WILL BE OFFENDED!!! >> I know this all too well!!! <<Also if my forum etiquette is off please inform me, gang. I've read the rules but I'm new and don't wish to offend
Hi Ian! I guess two of us are now pondering this. What rack format is that designed for? I am NOT up to speed on Eurorack and Eurocard, but after a quick look for info on both, I didn't immediately see anything to accommodate those dimensions. I'm guessing a version of Eurocard?Here is a very rough front panel layout for a 7U 40mm wide channel module. XLR input at the top followed by +-10dB trim, a pair of AUX sends (with space beside for toggle or push button pre/post switch), pan and 100mm fader. There is space beside the fader to fit toggle or push button solo and HPF switches.
[Here is a very rough front panel layout for a 7U 40mm wide channel module] -- Are Euro-rack dimensions different than what the EIA-310 rack dimensions are here in the U.S.? I ask this because the dimensions I am seeing in your FPD panel dimensions are not jiving with what are considered to be the "nominal typical dimensions" of 19" rack equipment here in the U.S. As an example.....Here is a very rough front panel layout for a 7U 40mm wide channel module. XLR input at the top followed by +-10dB trim, a pair of AUX sends (with space beside for toggle or push button pre/post switch), pan and 100mm fader. There is space beside the fader to fit toggle or push button solo and HPF switches.
Front Panel designer can export an entire panel as a dxf file but I think it can only import a panel outline which may explain the errors. I have never tried importing an entire panel in dxf format into front panel designer. I posted it as dxf mainly for the benefit of @darth fader who I suspect is not familiar with front panel designer but is with dxfWhile I was able to easily import your DXF file into FPD, I received the following errors
Eurorack is actually a DIN mechanical specification. The synth boys hijacked it many years ago and used the same name for their standard 3U high modules but the specification allows for modules of any number of U (3U, 6U and 9U being common). I chose 7U because it is just big enough for what we need and the synth boys make some nice 7U cases that we could probably modify to make it accommodate a 7U module - or you could complicate things a bit and fit the fader in a 4U module and the rest in a 3U moduleif you have specifics question on Eurorack (not only dimensions) feel free to ask. I have done plates in the past (and still able to) but I'm sure somebody else here is able too!
I don't see the point in this discussion, but maybe I'm not understanding, since OP was looking for a desktop line mixer.
Eurorack btw is "3U" height and lately some manufacturer started crafting "1U" modules. you can find "7U" height CASES for Eurorack where there are 2x3U rows + 1x1U row (just look for an Eurorack 7U case on the internet).
the "1U" row was born for utility modules, nowadays they put VCOs LFOs and so on as well
Everything you say is correct. I am not suggesting complying with the synth boys Eurorack specification for everything. In fact Eurorack is a professional standard:OK, the 7RU part confused me. I was finding articles like this, from the format's originator:
https://doepfer.de/a100_man/a100m_e.htm
Wikipedia only mentions 3U height.
https://en.wikipedia.org/wiki/Eurorack
I'm not a fan of the I/O connectors on the front....and I don't see anything in the Eurorack spec for busing. shrug.....
Brispecification parts of which the synth boys took, simplified and called by the same name
All I can tell you is I did not specify a corner radius when I designed the panel. Maybe what you see is the default minimum radius FPD use. You could try creating a plain panel in fpd with no corner radius, export it to dxf and check the corners.[the panel is rectangular] -- You may want to check that out. Here is how your DXF file imported into Front Panel Designer:
I'm up north in Dyer Indiana Close to chicago... which makes me a "Region Rat"[if my forum etiquette is off please inform me. I'm new and don't wish to offend] -- Don't worry about this, but just be aware of the fact that.....while you are on this forum posting your comments and responses, it doesn't matter how cordial, nice and/or pleasant that you are in your writings, at some point-in-time.....SOMEBODY ON HERE WILL BE OFFENDED!!! >> I know this all too well!!! <<
By the way, what part of Indiana are you located? I grew up in Indy, used to work at WFBM (now, WRTV) and I also worked in a couple of Indy recording studios before moving out here in Maryland to work with "one of the largest concert sound-reinforcement companies in the world" back in the early 1980's. Now, I "design stuff", while working-from-home.
GOOD LUCK AND WELCOME TO THIS FORUM!!!.....
