Compact desktop line mixer?
Front Panel designer can export an entire panel as a dxf file but I think it can only import a panel outline which may explain the errors. I have never tried importing an entire panel in dxf format into front panel designer. I posted it as dxf mainly for the benefit of @darth fader who I suspect is not familiar with front panel designer but is with dxf
When it comes to the engraving of text and so on, I no longer specify engraving because it is expensive and limited. Instead I specify UV printing which I have found to be just as durable but a lot cheaper and you can easily do graphics if you want to. I don't know if Frank can do this yet.
I am having breakfast at the moment (it is 9am here) using a laptop so I don't have access to the fpd file. I will post it later today when I get over to the workshop.
By the way, the panel thickness I chose was 2.5mm and there are no corner radii - the panel is rectangular.
Much appreciated Mr Ian! You are correct about not being familiar with front panel designer and I can load dxf files directly into "my" Proto Trak dpm rx3 milling machine here at work
