Compact desktop line mixer?
All connections should be on DB25...this isn't 1983. All modern patchbays and most 8 channel preamps, 500 racks and everything else is on DB25. There should be very few dedicated individual in/outs. Cheaper, easier manufacturing , easier hookups.
DB25 was invented in 1952….so I don’t know what the year has to do with it. Personally, my interface and patchbay are ¼” TRS.
I might be a strange example because I have a Dangerous Source that acts as both the D/A for my main outs and my monitor controller. The rest of my hardware goes through my other AD/DA converter (a MOTU).
You bring up a good point though. I guess I had been thinking that I would monitor off the board while I was mixing, then print the mix to the DAW, and if I wanted to listen back afterwards, I could just patch back into the stereo return and listen through there. I have meters to know how hot I’m hitting the DAW, and digital doesn’t alter the sound enough that I feel like I need to monitor the returns while printing. I know that’s not how things were done in the tape days though.
OK, your workflow is similar to some folks I know who don't have a desk of any type.....using an external monitor controller. I only have a vague idea about one of my friend's setup, but there is a UA monitor controller of some sort along with other UA digital interface gear. No analog desk; a 500 rack that somehow ties into A/D and D/A convertors.
But, with this project, the mixer IS the monitor controller. CR level, solo listening, speaker select, etc.
Bri
I had thought about that. The x-desk used multiple DB-25's. OTOH, the LILO used XLR and TRS jacks. But, it was a much larger mixer.
DB-25's pretty much eliminate the possibility of a DIYer "easily" doing their own metal work. Chassis punches are incredibly expensive, and drilling a bunch of overlapping holes and then spending a ton of time with a small file is very tedious and the results look crappy. I can easily make a panel with a drill press and some Greenlee punches, but draw the line at manually "chopping" odd-shaped openings. Shrug....
Bri
@OneRoomStudio I have an UNfeature Creep idea. <g>
Instead of the multi-segment meter on each channel and the peak indicator, instead use a "three-step" indicator for Signal Present (-20?), Normal (0) and Clip (+20?). Either a single tri-color LED or three individual LEDs. There is a way to add a pre-fade sample into the readout circuit to catch clipping of the input buffer as well.
Perhaps a single multi-segment meter could "watch" the Solo audio bus?
As best as I can see, the x-desk and LILO have NO metering or clip indicators on each input.
Deleting the meters on each channel greatly simplifies the circuity and reduces required panel space.
Bri
I can't seem to access the file this way.
[I can't seem to access the file this way] -- Since this forum is essentially "an engineering forum", I would think that the creators and/or moderators of this forum would allow it to be more accommodating with it being able to attach the many types of CAD-design files that all of us commonly use. This would then allow all of us to freely exchange our various types of CAD-design engineering files amongst one another without the need to "trick" the system into believing we are attaching an allowable file-type, when in reality, we're not!!! Is there a reason why CAD-design files are not allowed to be attached to messages here, but MP3's and WAV files are? HMMMmmmmmmmmm......
In any case, recently when I uploaded an -- STL -- file for RuffRecords to review which was renamed in the manner he has detailed, he afterwards made no comment about having any problems downloading and importing my file to him, other than that he was able to import my file and use it. However, and perhaps similar to your own experience upon accessing RuffRecords' attached FPD file, I did initially receive a "Black Message" as you have indicated. But, it's an easy fix to do.
Just place your cursor over the attached file and do a "Right-Click". You'll get a pop-up menu. Scroll down, select "Save Link As" and name the file to whatever you want.....>> BUT!!! <<.....just make certain that your file has an -- .fpd -- filename extension and then click on "Save". You should be "GOOD-TO-GO"!!! It worked for me!!!
GOOD LUCK!!!
