diko2 said:
Hi everybody,
Thank you all for your replies.
It's interesting to see that there is so many point of vue.
And here's yet another one.
After a deep inspection on the board it looks that it was some greasy thing that stick the inner pot.
Maybe the "too much of bad lube" scenario was the good one.
So i free the 40 bad pots with a small drop of isopropyl on the shaft (at the junction of the inner and outer).
Wait 1 min and then try to make it turn.
The first turns were very difficult and after maybe 10 turn it's free as new.
Listen to all EQs: everything work fine. Hope that it will last.
It won't. Alcohol is quite volatile, and will evaporate soon, leaving behind the thick gunk that you started with. But you are treating it in the right place, nowhere near the innards.
I believe your original lube was a petroleum based grease, and not all that highly refined, meaning it was a blend of many different viscosities, many different hydrocarbon chain lengths.
Over, what, 30 years?, the shorter hydrocarbon chain, more volatile components have evaporated, leaving behind the heaviest components, basically something akin to tar. Constant use helps prevent this, as turning a knob occasionally keeps them all mixed, where non-use, especially when stored at higher temperatures seems to allow the lighter components to migrate to the surface where they can evaporate, and they do.
I hesitate to give advice on what to do with your new cherished console, but if it were mine, I would just use a tiny bit of light oil, 3-N-1 or similar, to at least get something resembling a blend of a useable viscosity back in there. If a pot doesn't free up, add a touch of a solvent, I use toluene. Just don't drip whatever solvent you use on the console paint, if it doesn't dissolve it, it will dull it. A piece of cardboard with a pot-thread sized hole helps with this.
The toluene will evaporate quickly, but it helps to break any crusty surface skin preventing the light oil from getting in where it needs to mix with the tar.
I have a Soundtracs 40x12 monotor board that I have to do this to on occasion, while not concentric knobs, it has those wimpy little 4mm white plastic D-shafts, and they get impossible to turn, the knob will split first.
I put a marker dot under the knob on the mounting nut, to keep track of pots that I have done this "back-woods-treatment" to, the next time around, it is rarely the same ones.
Like you, I have no intention of pulling every channel, unsolder every pot, disassemble and rebuild, and put it all back together. Screw that nonsense.
Gene
