Nice suggestions. I would like to
not get my face blown off so I appreciate the "Danger, Will Robinson!"-type responses.
I was unsure of how to do the ground rail/0v connections and based it on my memory of
this thread about converting a bipolar schematic to monopolar. It suddenly dawns on me that
you would never use a center tap for a PSU without a negative side (after reading Harpo's comment.) Am I right about this? You would always wire the secondary in series or parallel. Referring to
Mark Burnley's transformer hookup diagram.
[quote author="JD"]
As drawn, the leftmost two diodes of the bottom diode bridge will short the negative half of the secondary winding (during each cycle) to its center tap! This is generally not what you want.
[/quote]
Thanks!!
[quote author="Harpo"]
while you're at it, also change the connection of pin 1 and the 4368R voltage setting resistor in the +24V part, wired the same way as in the +48V part.
If you only need 0V/+24V/+48V and want to stick to a center tapped transformer, you may exchange the 7818 and 7918 with a 7824 and 7924 regulator, remove the +48V part and remove the labeling. The previous labled -18V out will become the 0V, previous 0V will become +24V and previous +18V will become +48V. Yust make shure, there is no connection from previously labled 0V to gnd or the case. Should work, but can lead to trouble if anybody has to fix it one day.
A maybe better approach could be a dual secondary transformer, using one winding for +24V regulation and the other/separate winding to a voltage doubler and 783 regulator (or 317 regulator with some additional zener/diode safety).
just my 2ct.
[/quote]
Thanks for these suggestions - this gives me a lot of good suggestions, and got me using my brain about how the secondary should be wired.
[quote author="Fucanay"]
Let me clarify, that it was MattA, not me, that originally did that fetboy PSU and he shared that with the group a long time ago and I just brought it to the forefront because I wasn't understanding it and had problems with it.
[/quote]
Thanks for the clarification. I was previously referring to that PSU as the "Fucanay/PeterC Fetboy PSU."
I missed the original post from MattA.
That said, I don't think what you're trying to do Keith's board is all that different than what Matt did with Peters PSU board, except that with Peters, it was already designed for the LM317 and on Keith's you need a second bridge rectifier.
[/quote]
That's right, I'm trying to do the exact same thing. But I thought this would be easier because I was getting lost in the other schematic and wasn't sure it was a working schematic. But I suppose the LM317 and 1 less bridge could actually make the PeterC-based one simpler. Really I just think it's fun and interesting.
I too would like to see a ready made PSU board like this, but with some additions to it. Like for instance, a place to put in a large watt resistor to soak up some over voltage before the regulator if the transformer is a bit over spec. What rodabod said about selecting the right transformer is important, but in my case, it wasn't so easy because of every transformer I bought being over the stated voltage output. My 12-0-12 actually put out about 29 volts when wired in series. Rectify that and you have a little over 40VDC and then you have to regulate down 16 volts. I put 20ohms worth of resistors after the rectifier to soak that up, but it's wasted energy at that point.
[/quote]
Agreed. I've encountered the same thing, as I noted in the other thread: overvoltage on many commercially available torroids.
I'll rework the schematic based on everyone's comments.
Is there any reason to keep the center tap for this application?
I'm going to remove it if there's no reason for it. Although I'm still confused about what "0V" on a power supply board would be without it.
