"Hi-railing" the opamps can be used for "sag emulation" as well if a certain mod is performed ...
http://moosapotamus.net/IDEAS/F2B/alembic.htm
Replace the tubes with 2×IRF710. Sources must now have separate low negative rail (maybe from heaters), i.e. bottoms of catode resistors/caps go to negative rail.
(Or re-bias the gates.)
If it smokes, it's your expense ...
Let's see about that :twisted:Using heroic rail voltages seems to me to be the "last cheat"
