Winston O'Boogie said:
One reply to one question:
1954U1 said:
Then where are the actual measurements??
To measure this effect is little more than child's play. The measurements have been presented to death many times and by many people. It is a real effect. However, I think you should try it yourself as proof...or not.
I was only arguing about how the phenomenon is presented in the Cheever's paper..
I've seen the fig 3-2 on page 66[pdf's 73] of the doc.
I've only thought it was a bit unfair and un-realistic to make a test with only a single-ended circuit with an external current source as the one pictured in fig 3-1..
Excuse me for that, I know I'm a nothing in electronics experience, I try to express things that seems obvious even to me..
Anyway, yes and thanks, you're completely right.
I have [now] enough measurement instruments, listening system and raw skills to make the tests by myself, using real circuits.
The thing, in the Cheever's paper, that interested me at most is the one preparing the conclusion:
In review, global or single stage negative feedback is not required for audio
amplification if a single-ended design is chosen. The design will contain harmonics at
much higher levels than the same device used in a feedback amplifier, but, the harmonics
may match the ears self-generated envelope of harmonics, and result in a better TAD
figure. In general only two gain stages will be required, in contrast to at least five with
modest feedback level amplifiers.
Also, this distortion spread we're talking about is not just a 'human' condition. It is, however, a natural one. It occurs in air and inherently in the active device before large amounts of feedback are applied.
Yes, distortion spread is in nature too, not only in human ears..
Again from Cheever's doc, pag 66 [pdf's 73], he states:
Why plot 98dB? Because it is clear from the aural
harmonic envelope that the fall off matches most closely the zero-feedback data!
[the whole 98dB SPL / 2 Watt / 2 speakers / 1 mt seems really, to me, a bit a trick to fit the data..]
Moreover:
why should we try to give the speakers a sound with a distortions distribution ultra-precisely matching that of the human ears?
There is some universal law behind our "aural harmonic envelope", so the musical instruments, the air, the speakers materials,
the without-negative-feedback electrons, all have exactly the same distortions distribution, and so its "right" to join that law?
And [I'm always referring to the paper], one thing is to state the obvious, i.e. that the 3rd and higher harmonics are unpleasant and to avoid..
another thing is to say that an amplifier should super-exactly mimic the human ear behavior in order to sound good.
[but I have to admit.. this last sentence sounds good indeed ;D]
Another part of the problem I have with amplifiers using large amounts of n.f.b., or a non "A" class topology, is that the distortions are non monotonic. They do not rise gently with amplitude. Monotonicity is also is a natural phenomenon.
I was only thinking that all these class A currents are a bit of waste, if we can do nearly the same with well designed circuits using NF..
but maybe I see your point.
How much "nearly" we can go, and how difficult it is?
Should not instead we use high voltages and only class A topologies, and stop worrying about "discrepancies" in distortions distribution?
Anyway, many thanks for let me better understand this issue.. really.
