My question is a two-parter, I suppose.
Part 1:
I've got an LA-2A in front of me, and I'm curious as to how to measure the total current drawn by the circuit. Why am I curious? Well, I noticed the power trafo is spec'd to deliver 40mA of current at 500V. But if I add up the total plate current (as read from datasheets) drawn by all of the tubes, I get the following:
1 x 12AX7 = 2.4mA (1.2mA current per triode)
1 x 12AX7 = 2.4mA (")
1 x 12BH7A = 23mA (11.5mA per triode)
1 x 6AQ5 = 30mA max plate current
Total = 57.8 mA for a single LA-2A.
So how is a trafo spec'd to deliver 40mA able to deliver enough current to the circuit? Obviously, the circuit isn't drawing that much current. So...am I adding typical plate currents incorrectly? Am I going about this in completely the wrong way? And, of course, how do I measure actual current drawn by the LA-2A? Disconnect R29 and measure across?
Part 2:
Ultimately I'm diving into this stuff so that I can eventually create a spec for a custom power transformer for a project I'm working on. But I need to know how to estimate current draw first. I know what tubes I'll be using, but obviously just adding up "max" or "typical" plate current draw according to datasheets isn't the way to go...
Part 1:
Part 2:
